  3. Allegro 'show measure' units
  • Views 15626
gvleming03
gvleming03 over 15 years ago
Hi all,
 I'm pretty new to using Allegro for PCB design, and I was wondering what units are quoted by the 'show measure' command. The numbers in the pop-up window display no units, but I'm curious as to how to figure out the length (preferably in mils) of traces on my PCB. Thanks.
  • EvanShultz
    EvanShultz over 15 years ago
    Hi gvleming, welcome!
    The DB units are shown in the Design tab of the Design Parameter Editor form (Setup > Design Parameters).
    If your DB is already in mils, finding the length of a trace is easy, using Show Element (as you've discovered). Show Element for a Cline (connect line) will display the length, etch length of the entire net, and Manhattan length of the net.
  • rinj
    rinj over 15 years ago
     Can anybody answer,
    Show measure displays the following details: (Tool: Allegro PCB Editor 16.3)
    What is the difference between each term? what is Manhattan Dist?
    Dist =
    Total Dist =
     Manhattan Dist =             Dx =            Dy =
     No air gap, ineligible element: Grid Point .
    rinj
  • EvanShultz
    Hi rinj,
    Hit F1 when in "show measure" mode; the Cadence Help page for this command should answer your questions.
