  3. Allegro SKILL code needed
  • Subscribers 163
  • Views 15472
evgy
evgy over 15 years ago
I need to check distance between "SILKSCREEN" - TEXT and Assembly, and i don't want to make mesurement from bBox to bBox.
Maybe someone knows how to convert TEXT object to SHAPE?
  • eDave
    eDave over 15 years ago
    See attached function to draw text.
    You might also like to consider using my autosilk utility that I have uploaded here at various times. The latest release is 8.23.
    drawTextFunction.zip
  • evgy
    Hi Dave! Thank you very much for quick response, but your function isn't the exat solution for my problem.
    I want to choose a component and check the "Air Gap" between its "RefDes/Silkscreen_Top" and "Package Geometry/Assembly_Top". The only measure result i get is "air gap" between some point on "Package Geometry/Assembly_Top" shape and xy point of the text object.
    i want to create a function which will check "RefDes/Silkscreen_Top" to "Package Geometry/Assembly_Top" shape  vicinity violation.
  • evgy
    I'm sorry for attacking you with questions, according to your point rate you GIANT of SKILL programming , so i want to use the opportunity to ramp up with my SKILL knowledge.
    Can you help me with interactive function that will lock (prevent) x or y axis moving while "MOVE" command.
    Thank you in advance,.
    Yevgeniy
  • eDave
    I do understand what you are trying to do. By creating shapes from the text you should be able to use the axlAirGap command to then measure between the newly created shapes and the assembly shape of the component you select. It's not a huge amount of programming and the code I posted should help you.
    Dave
  • eDave
    There's a Skill forum here where this question would be better placed. Please post again there and I'll give you some clues.
