  3. PCB editor doesn't let me route
  • Subscribers 163
  • Views 1493
van1
van1 over 15 years ago
Hi
I have to modify an layout which is done with PCB Editor. I know there is a BGA region in which there are  many DRC errors but it is the way it's done.
Now every time i want to reroute a trace in this section PCB Editor blocks me from routing because the DRC check. I tried many tricks but none was working.
Any advise ?
Thank you
  • Rik Lee
    Rik Lee over 15 years ago
    In the Options tab while you are in the add connect command set "Bubble:" to 'Off'. This will allow you to add clines and DRCs will be created.
  • van1
    It works !!! I appreciated a lot your help
    Thank you
  • redwire
    redwire over 15 years ago
     Then examine the DRC to see why it's happening -- you have a setup problem.
