  3. Allegro Design Entry HDL retrieve version number SKILL
  • Replies 8
  • Views 17731
argeJtag
argeJtag over 15 years ago
 Hello folks,
Is there a way to obtain the version number of Design Entry Hdl (e.g. 16.5) by a SKill command ?
Thanks in advance,
ArgeJtag
  • eDave
    eDave over 15 years ago
    I suggest querying the CADENCE_VERSION environment variable (using getShellEnvVar).
  • argeJtag
    My Windows system does not have this environment variable. Also I installed version 16.3 and 16.5. If there is a environment variable CADENCE_VERSION which version will it return ? 16.3 or 16.5 ?
    So I do not think that this is the ideal solution for my problem, correct me if I am wrong.
    ArgeJtag
  • RFDTeradyne
    RFDTeradyne over 15 years ago
     Open Allegro and type "set" in the command window. I see a variable"cdsversion" that has the version in it.
     Use axlGetVariable to get it or any other useful looking variable.
  • Khurana
    Khurana over 15 years ago
    Actually Dave's method should work; look for CDSROOT if CDS_VERSION doesn't exist.
  • eDave
    Try this if you are still having problems:
    cnGetMsgInfo(cnSendCommand(handle, "show release"))
    Dave
