  3. Sliding a line by certain distance
  • Views 13117
themaccabee
themaccabee over 14 years ago
I ve drawn a vertical line in board outline (100 mils length) in allegro & i need to slide it to say, left by 10mils .How can i do it without redrawing?
Thanks for any help.
  • steve
    steve over 14 years ago
    Hover over the item until it highlights then RMB - Move, then at the command line type ix (or iy) 10 or -10 depending on which way you want the line to move. You can use ix and iy and command line entry for adding items as well.
