  3. How to Hide a Pin Name in OrCAD Capture
  • Views 14682
cshinyc
cshinyc over 14 years ago
I am using SPB16.2, OrCAD Capture.
I'd like to hide some of the pin names in one device, but the pin number and pin need to be displayed.
When set Pin Names Visible as False, all the pin names in the device are hidden. But I only want to hide some of them.
If I set them to power pins, and hide the pins, the pin name and the pin itself will be hidden.
Anyone have any suggestion?
Thanks.
  • redwire
    redwire over 14 years ago
     I think you've pretty much figured out how it works so the only other suggestion I have is turn off all names and use text to name the pins you want named.  A lot of work for not a lot of gain :(
  • cshinyc
    Yep, maybe that's the only way to do. :-) But not a good try.
