  3. use of Layer Mapping
  • Views 15365
jean1125
jean1125 over 15 years ago
 hi!
i just want to know what is the used of Layer Mapping. Can it be used to convert footprints in PADS file
to allegro?how to do that?
Please help.Thanks!
  • Ejlersen
    Ejlersen over 15 years ago
    Hi When you Import from Pads you need to specify a layer mapping file, just specify One that does not exist or is empty to get a gui for creating this.
    The layer mapping tell what layers in Pads translates into what subclasses in PCB Editor. Or more simply, just use the Pads_in file from the installation directory
    You Can translate Pads board files that contains footprint (decals) amongst other information. After translation The footprint Can be exported using file-export-libraries
    Best regards
    Ole
  • jean1125
     Hi!
    thanks for your prompt response.im a new user of allegro, before we are using PADS
    we wanted to convert all footprints from PADS to allegro so we can use it for our upcoming designs
    i tried to use the mbs2lib to convert footprints but it is not translating any symbol.in this mbs2lib, there is an
    optional scheme that has this Layer Map, is this where i need to specify a layer mapping file?how?
    i tried to use the PADS_in file but im not sure how to used this and from the output of this file how can I translate the PADS footprint to Allegro?
    Can you give me a detailed process how to do this??
    Thank you very much for the help!
    Best regards!!
