  3. How to update dynamic copper shape after islands have been...
  • Subscribers 163
  • Views 20343
How to update dynamic copper shape after islands have been deleted?
HWDesigner
HWDesigner over 14 years ago
I created dynamic shape outlines, assigned to net names. I deleted the copper islands (within pin fields).
Now I want to update the shape-to-pin spacing in the constraint manager to get copper between the pin fields. Since I already deleted the islands in these areas the constraint manager has no affect. Is there a way to bring back the deleted copper islands so the copper plane will change from a shape constraint adjustment?
  • oldmouldy
    oldmouldy over 14 years ago
    When you ran Shape>Delete Islands, PCB Editor actually added "Manual Voids" to remove the Islands. To restore the Islands, use Shape>Manual Void>Delete, you probably want to turn off all of the colours, apart from <layer>/Boundary so that you only see the Shape and Void boundaries.
  • Prasanna
    Prasanna over 14 years ago
    Oldmouldy,
    Thanks a lot for sharing this tips..
    I was using some other way to take out the voids which is kind of time killing....
  • HWDesigner
    Thank you.
    I also was going through the long way to get around this problem. And I figured there had to be an "easier" way. So thank you again.
