  3. Allegro reports - Component Heights
  • Views 5850
HWDesigner
HWDesigner over 14 years ago
I'm having some trouble with creating a custom report in allegro. The Tools-Reports-New/Edit dialog box is very confusing to me.
I'm trying to create a simple report to show the heights of each component (top and bottom). I use this data for the side view on the assembly drawing. The heights are saved as a shape outline on class PACKAGE GEOMETRY subclass PLACE_BOUND_TOP.
A show element on the shape gives me: PACKAGE_HEIGHT_MAX  = 500 MIL (as an example)
How can I get this information on every part on the board in a simple report?
  • djhutchi
    djhutchi over 14 years ago
    Try this as a starting point:
    GEOMETRY
    CLASS = PACKAGE GEOMETRY
    SUBCLASS = 'PLACE_BOUND_TOP'
    SYM_TYPE = PACKAGE
            OR
    SUBCLASS = 'PLACE_BOUND_BOTTOM'
    SYM_TYPE = PACKAGE
      SYM_NAME
      COMP_DEVICE_TYPE
      REFDES
      SUBCLASS
      COMP_PART_NUMBER
      COMP_HEIGHT
      PACKAGE_HEIGHT_MAX
      PACKAGE_HEIGHT_MIN
      IDF_OWNER
    END
  • HWDesigner
    Thanks for the quick response. Did you create this code manually? I was trying to create a report from the allegro form through Tools->Reports->New/Edit and all the options and tabs were very confusing to me. But it looks like you created your own code.
    I have a programming background and wanted to understand the code for myself. I understand everything from Line 9 and below (SYM_NAME). Before that I don't understand. I see an OR statement but no curly braces as in traditional programming grouping the statement.
    Is there some sort of tutorial or examples on how to program reports? Or is this skill programming?
    Also when running this code I receive multiple entries for a single part. For example, I'd see R100 4 consecutive times (with exact information). I think it's how the shape is created in the library because when I show element on the shape there are multiple XY locations.
  • djhutchi
    Most of the Allegro ‘reports’ are based on using Allegro’s ‘extract’ functionality to get the data from the board file, the Cadence supplied Extract view files are located in %cdsroot%\share\pcb\text\views
    Basically searched that directory folder for files containing  PLACE_BOUND, then used the contents of nidf3_vw4.txt as the base for what I sent you…
