  3. Repeat a Command
  • Subscribers 163
  • Views 14180
Repeat a Command
Bennigin
Bennigin over 14 years ago
Does anyone know of a way to repeat a command? For example: I have a polygon that I need to move several vertices. I select the shape, select a vertex, and I type "ix 100 28" on the command line. Is there a way to repeat that command for moving the next several vertices instead of doing it over and over.
  • Nagaraj Shanmu
    Nagaraj Shanmu over 14 years ago
    Use alias command to repeat a command
    Syntax: in allegro command prompt
     alias <function key> allegro command to execute
    In your case
    alias F2 ix 100 28  <return>
    this maps your allegro command to function key F2. Now when you press F2 it executes the allegro command mapped.
    This can be added to your env file to store in for other designs
    Good luck.
    Nagaraj.
