  3. Installation Error - Entry point not found
  • Replies 8
  • Views 9660
cameo
cameo over 15 years ago
I guess similar topic must have been discussed in the past. Not sure whether its the right thread to post again.
Anyways, Here's my problem:
Installed Allegro 16.2
It gives an error while trying to open Design Entry
Entry Point Not Found
The procedure entry point ?SetCpmHandle@CDSSmlLibReader@@QZEXPAX@Z could not be located in the dynamic link library cmpropertyserver.dll
Any help appreciated
  • Alok Tripathi
    Alok Tripathi over 15 years ago
    Check path setting in your system to see this is correctly pointing to SPB 16.2 installation.
  • cameo
    Thanks for your response.
    Can you be a little more specific please.
    Do you mean at the Environment variable setting?
    System variable CDSROOT is being set to the root directory C:\Cadence\SPB_16.2
    Thank you
  • Alok Tripathi
    Yes. I mean PATH variable setting under enviorment variables.  Simplest way to check this could be to open a dos windows and type PATH in that.
  • cameo
    The variable PATH has a value mentioned in the system variable
    If I change the variable value to C:\cadence\SPB_16.2, the Project Manager itself doesnt open. dll missing error.
  • Alok Tripathi
    Can you try bringing %CDSROOT% related string in front of path variable: i.e.
    %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%CDSROOT%\tools\bin;%CDSROOT%\tools\libutil\bin;%CDSROOT%\tools\fet\bin;%CDSROOT%\tools\pcb\bin;%CDSROOT%\tools\specctra\bin;%CDSROOT%\OpenAccess\bin\win32\opt;%CDSROOT%\tools\Capture;%CDSROOT%\tools\PSpice;%CDSROOT%\tools\PSpice\Library;C:\Program Files\ActivIdentity\ActivClient\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\10.0\DLLShared\;%QUARTUS_ROOTDIR%\bin;%QUARTUS_ROOTDIR%\eda\sim_lib\excalibur\swift\lib\pcnt.lib;%QESS_ROOTDIR%\bin;
    Also I assume you are running 16.2 version of Project Manager. Try running Allegro or some other product also to confirm if this issue is with specific tool or generic. If you have installed selected set of product, try after installing all products.
