  3. No PSpice Model for Connectors found in Library
  • Subscribers 163
  • Views 16680
benjaminoven
benjaminoven over 15 years ago
Hello, I am using the Connector library to use the following two parts: CONN PLUG 32X2 CONN SOCKET 64X2/SM that were both built into the installation of Orcad 16.2 I am trying to show how the wires will connect the two connectors and generate a netlist. I did a few connections and tried to create a netlist and received an error for each of the connectors: WARNING [NET0093] No PSpiceTemplate for J1, ignoring There are also now green circles above the parts. Any help with fixing the missing pspice template? I do not need to run any simulations, just a netlist. Thank you.
  • oldmouldy
    oldmouldy over 15 years ago
    You are trying to create a PSpice netlist, from PSpice>Create Netlist, hence the messages about PSpice Template. You need the regular, PCB netlists, Tools>Create Netlist, PCB Editor tab for PCB Editor, Other tab for the other PCB netlist formats.
  • benjaminoven
    Would that still be within the "capture" application or would that be in a different one like the PCB application? My tools in Capture only has "customize" in it. Thanks again
  • Alok Tripathi
    Alok Tripathi over 15 years ago
    Yes. That would be still in Capture Application. Select the dsn (design name) in Project Manager View to get complete Tools menu.
