  3. Job Description - Staff PCB Designer
  • Views 1405
aruprecht1
aruprecht1 over 14 years ago
I know this a little off base, but could sombody share with me a job description for a Staff/Senior/Lead PCB designer
as related to using Allegro Design software? Thanks in advance
  • Jeff Underwood
    Jeff Underwood over 14 years ago
    I'm not sure how this job description would be changed to make it more "Cadence" specific, but a principal staff designer shared this with me about 15 years ago as an incentive to strive for his position and I have tried to follow this ever since. It is a broader description of what is expected of a senior level designer/engineer:
    Proactively identifies and applies technologies
    when preparing program plans.  Seeks out
    information and enforces technology standards.
    Determines technology required to meet
    market requirements and competitive chal-
    lenges.  Is sought out for recommendations
    regarding technical issues in multiple areas.
    Anticipates technology trends & takes approp.
    action.  Identifies future technical staffing re-
    quirements & obtains necessary commitments.
    Anticipates obstacles and develops ways to
    overcome them.  Takes on additional respons-
    ibility and initiates actions based on his/her
    convictions.  A self-starter who needs minimal
    supervison.  Willing to take calculated risks to
    accelerate a program completion.Very effective
    in pursuing alternatives to deal with problems
    encountered in a program.
    Has made breakthroughs in problems others
    were not able to solve.  Is consulted by others
    where innovative approaches are needed.
    Challenges others to think in unique
    terms and stimulates creativity and innovation
    in addressing issues.
    Has helped others expand the area for which
    they make contributions.  Is consistently
    sought out by others in order to provide the
    focus for solving critical problems.  Solutions
    and recommendations usually become
    benchmarks or standards in working similar
    problems throughout the organization.
    Effective at quickly solving problems and is
    able to draw accurate conclusions.
    Is able to cover a broad range of
    problems.  Is able to influence other's
    decisions. Effectively manages a broad network
    of communications as a tool in problem solving.
    Contingency plans for major steps/critical paths
    are included in overall plans. Anticipates and
    makes changes in program plans in advance to
    prevent negative impacts. Goals are well
    communicated and understood by all parties
    involved.  Routinely exceeds desired results
    in meeting goals.
    Can strongly influence the decisions of others
    through persuasive skills.  Sought out by
    others for advice on dealing with people and
    can prevent conflicts including potentially
    volatile or sensitive situations. Is very effective
    in discussing even complex subjects.  Docu-
    ments & reports have been used as examples
    for others to follow.  Provides a continuous flow
    of accurate and detailed information.
    Is sought out by others for guidance and
    counsel.  Has demonstrated leadership skills
    in multiple areas.  Excels in coaching others
    towards achieving goals.  Quickly develops a
    strong sense of cooperation and a high level of
    motivation. Has developed people who have
    moved into positions of greater responsibility.
    Often uses knowledge of the market to identify
    new business ventures/process technologies.
    Develops subordinates to outstanding
    performance.  Utilizes strong coaching and
    counseling skills that have resulted in
    optimizing others' performance and careers.
    Has successfully identified and resolved,
    within the realm of his/her authority, all
    performance issues.
    Encourages, supports, and assists in main-
    taining a team atmosphere and cooperative
    environment which has led to permanent
    culture changes directed toward proactive
    problem-solving and results.  Mentors team
    activities, and addresses conflicting goals
    between departments.  Quickly gains confid-
    ence and respect of others.  Is sought out by
    other managers for teamwork advice.  Team
    accomplishments are highly visible and
    recognized by others.
  • aruprecht1
    That’s a start for me
    Alan Ruprecht
    Staff PCB Designer
    L3 Communications (Display Systems)
    1355 Bluegrass Lakes Pkwy
    Alpharetta, GA 30004-8458
    770-752-5076    Fax:770-752-5495
