  3. Changing Oblong pad characteristic
  • Subscribers 163
  • Views 14359
dumarjo
dumarjo over 14 years ago
 I would like to know if it is possible to change the way that paddesigner is using to create the oblong pad. I would like to have the oblong radius reduced.
 Is that possible ? We are using 16.2
 regards
Jonathan dumaresq
  • dumarjo
    oldmouldy said:
    The "regular" shapes are automatically generated, if you need any differing shape, you must design the required Pad Shape in PCB Editor as a Shape Symbol, SSM, and then, in Pad Designer, set the Geometry to Shape and browse for the Pad Shape created in the Shape entry.
    I thought that was somewhere the rules to create a regular pad. Like a parameter file.
    regards
    Jonathan
  • dumarjo
    regards
    Jonathan
