  3. Unused layers
  • Subscribers 162
  • Views 14198
Unused layers
budnoel
budnoel over 15 years ago
Hello all –
Is there a command that removes unused custom subclasses from a design?  I am looking for a command similar to the “Compact” command in the Text Setup menu.  Thanks in advance for any help.
Bill Noel
  • redwire
    redwire over 15 years ago
     Not that I am aware of -- you need to use the setup subclasses command to remove the ones you don't want.  No real need to but I do it as well to keep the design clean.
