  3. Changing the colors from opaque to solid
  • Subscribers 166
  • Views 13352
pitbull107
pitbull107 over 14 years ago
 Is there any setting to change the opaque look of the colors to a more solid look? Version 16.0
  • KEN13
    KEN13 over 14 years ago
    Pitbull,
        Under Setup/User Preferences/Display/Opengl place a check in the disable_opengl box and restart the program.  I believe this may be what you need to change.
    Ken
  • fxffxf
    fxffxf over 14 years ago
    Under Display -> Color Visibilty open the dialog
    Select the Display tree item
    Then  under OpenGL Global Transparency set it to 100% plus set shape transparency to 100%
