  3. Package Keepout copy from file to file
  • Views 15591
tnehchuan
tnehchuan over 14 years ago
Hi, I am new to cadence Allegro Software. Been using Altium for the past.
Anyway,Just want to ask, is it possible to copy a template of  package keepout/keepin and the grometry from a old BRD file to another new template BRD file?
and also how to locate the reference point while copying?
  • girish
    girish over 14 years ago
    * File export subdrawing (temgroup & select what and all you want)from old board file & import to new board file .
    * One more method is file ->export-->IPF (set the visibility of the classes u want to extarct)while importing to new boad file  select the desired classfrom option menu
    *For reference point while copying make use of userpick to select the desired pick
    Girish
  • tnehchuan
    Hi Girish,
    Many thanks for your advice, But for the first method you advice export by sub-drawing, when i tried to import it to new BRD file, it show error  below : -
    ERROR(SPMHA1-161): Cannot open the design database file ... run standalone dbdoc tor on the file.
    Unable to paste the symbol - ("1268_1265E_MP_ONLY_CMT_MECH_R2" "MECHANICAL")
    can i know did i miss something???
  • girish
    Run DBDOCTOR (pcb editor utilities-->dbdoctor)on old board file ,then give a try .
    Girish
  • tnehchuan
    Hi Girish,
    I have tried use the DBDoctor, it checked with no error on it.
    I believe maybe my old board have packaged the template drawing on "Package Keepout>Top" as a "symbol"
    >>>Unable to paste the symbol - ("1268_1265E_MP_ONLY_CMT_MECH_R2" "MECHANICAL")<<<
    I tried to copied some "top Silk" to my new board by the sub-drawing method, its work..
    So it is have any method to copy the "symbol" to my new BRD??? other than the method two by IPF u suggest me on previous, because IPF method will copied all my "Top Package Keepout", but i only need some specific Top Package Keepout to copy to my new BRD.
    or do i need to add anything on my new BRD before i can import the sub-drawing?
    Please advice, Many thanks
    HC Tneh
  • girish
    Yes , In IPF export it will copy all the thing which is enabled during the export .(you can delete unwanted things).
    You are specifying as your keep-out defined as symbol , then try the below one
         *Export the libraries from old board file to some folder (FIle—>export->libraries)
         *Search the symbol by symbol name & copy to your working library folder (the path defined in User preference->library->psm & pad path)
          *in the new board file go to place manually in advance setting include library  & in the placement list u can find your symbol & place it
    Not sure whether this will work out !!!!
    Girish
