  3. REUSE Blocks in Allegro
  • Views 16129
DawnC
DawnC over 14 years ago
I have finally figured out how to created a reuse block in Capture and place it in Allegro.  Now I want to move the block.  It doesn't move as a block.  Is there a trick somewhere I am missing?
  • edhickey
    edhickey over 14 years ago
    set find filter to 'group' when using the move command
  • DawnC
    Ah…Feel kind of silly now J
  • edhickey
    If you wish to lock the elements of the module to prevent accidental movement of components or routes, assign the "locked" property to the module. You will still be able to move the module as a group entity.
     edit - property
    set find filter to "group"
    select the "locked" property from the available list
  • DawnC
    This is good to know. Thank you for the information!
