  3. Stack Layer Table
  • Views 15928
Stack Layer Table
tnehchuan
tnehchuan over 14 years ago
can i know how to place the Stack-up layer table on the BRD Layout?
  • steve
    steve over 14 years ago
    If you are using 16.5 then there is a cross section chart option under the manufacturing menu. If you are using a release earlier than that then there is a skill file available (on the pcb skill forum) called xsection or something similar which you can load and run from the command line in PCB Editor.
  • tnehchuan
     Hi Steve,
    i am using cadence allegro 16.3, i cant find the "skill file" in the PCB skill forum, perhaps could you direct or show me where is it?
    Thanks.
  • steve
    Have a look at:- /forums/p/10273/10595.aspx#10595
