  3. PADS library conversion to Allegro Library
  • Views 17311
baguhan21
baguhan21 over 14 years ago
Good day. Our company is immigrating from Mentor Graphics PADS to Cadence Allegro. I already found a way to import the layout of PADS to Allegro PCB editor but exporting the PADS library and importing it to Allegro is not simple.
I found a process on how to convert a PADS part into Allegro but this process involves converting a part one at a time.
is there a process in which i can convert the parts all at the same time and place them accordingly on the converted allegro layout.
thanks in advance.
-christian
  • Rik Lee
    Rik Lee over 14 years ago
    If you have the converted board in Allegro PCB Editor you can use File >Export >Libraries; select the elements you want to create and a directory to export them to then select "Export". This will create, for example, the .dra, .psm, .ssm, .fsm, .pad files that you need for later use.
    If you have a PADS design that has all of your library parts in it you would be able to recreate the entire library.
  • baguhan21
    it works perpectly... it seems now that it was a stupid question...
     thank you again.
  • baguhan21
    it works perpectly, it seems now that it was a stupid question... :D
     thank you again...
  • baguhan21
    by the way, can i add another question sir Rik... i successfully imported traces and parts into allegro but without nets, they all shows dummy net although I included "connections" when i exported ASCII from my PADS layout. i tried exporting the nets from the PADS logic and then importing it to allgro which says no error on netin log file and yet they are still dummy net. i also tried derive connections, same result. can you help me.
    very much appreciated.
    -christian
  • Cadpro2K
    Cadpro2K over 14 years ago
    I think you need to import "Routes" too. I've never had it happen when it didn't translate the electrical connections. Odd.
    Good day.
