  3. Align tool
  • Replies 21
  • Views 21679
Align tool
Silver John
Silver John over 14 years ago
Duplicate post in this forum, maybe it's more the right place. (It was posted to a PCB SKILL forum)
Present to you the tools to align objects on PCB.
Welcome for comments, bugs, suggestions.
Questions?
Who wants to can join to development.
Code in the repository: github.com/.../align
Installation described in the README.md.
 How it looks:
Align tool UI
  • Silver John
     You load scripts twice. Why, I don't know. Do not do that.
    Later I add checking for this situation. (thanks for suggestion :))
    Temporary sulution for "oops" error:
     in initHotKeys() procedure update next line:
         let( (aliases alias aliasFun _oopsAlias)
     Tell me how it helped. I can't test this solution now.
    Also you can simle definу alias in env file.
  • Welcome04
    Welcome04 over 14 years ago
    Hi John,
    I did not change the skill code but
    I load the skill code manually on the command prompt, the align tool menu pop out but the error still exit as below:
    Skill > align
    E- *Error* eval: unbound variable - _oopsAlias
    ERROR
    I will test out later, see whether the option of Align tools is working.Will let you know once I found anything strange.
    The pull down menu has no more align command if I manually load it.If I load it automatic on the apd.ilint, the pull down me having two align command.
    Thanks have a nice weekend.
    Regards
    Elaine
  • Silver John
    Fixed: *Error* eval: unbound variable - _oopsAlias.
    Get revision: 59:f5873beef39b.
    About double loading, I tried, but not reproduce it.
    • I load by apd.ilinit
    • I load by allegro.ilinit
    • I use both apd.ilinit and allegro.ilinit
    Now I'm using allegro.ilinit for load scripts in APE and APD.
  • Welcome04
    Hi Silver John,
    Thanks, it works for me now.
    Regards
    Elaine
  • Welcome04
    Hi John,
    This skill core is not working on APD16.5 P3.
    the error as beIow:
    E- Failed to open form align.form.
    E- *Error* axlFormSetField: argument #1 should be any user-defined (other) type (type template = "otg") - nil
    Regards
    Elaine
