  3. Design Parameter Dialog windows won't show up
  • Views 2030
newpic
newpic over 14 years ago
Can anybody help me to enable my Design Parameter windows? Somehow my "Setup/Design Parameters window" won't show up. The fold-A-way windows open but empty included Visibility, Find, and Options.  Example, if I want to add a rectangle, (Add/Rectangle), I hoove over my mouse to the Options window and it is empty.
 Please help.
I use PCB Editor 16.3, Windows XP Pro
  • oldmouldy
    oldmouldy over 14 years ago
    Try a View>Reset UI to Cadence Default, this might cure the issue.
  • newpic
    I did that and it does not resolve it.
  • newpic
     When click on Setup/User Preferences, there is an error on the command window "Unable to open form text file"
    Does anybody have any instruction how to fix this?
  • killyourself
    killyourself over 12 years ago
     The same problem. I want to reduce pin names in footprin (bga array with 229 pins). Because it is hard to understand relations of pins and numbers.
    Designe parameters tools was not start after click on it. Few days ago all worked fine. I was modify block text with this tools.
    Thank.
