  3. How do I stretch unfilled shape.
  • Views 18366
DrLightning
DrLightning over 15 years ago
Help/About says I'm using OrCAD PCB Editor version 16.3 (16.3 S020 (v16-3-85BE)[11/1/2010] i86. I have a complex shape drawn using menu command shape/polygon, on layer Constraint Region / Top. The mechanical design has changed and I need to take an imaginary line across the shape and stretch everything to the right, rightward 1/10", thus stretching the middle of the polygon at my imaginary line. How do I do this, please, without having to redraw the whole polygon? Thanks very much
  • KEN13
    KEN13 over 15 years ago
    Hey Doc,
         I believe what you want is from the top menu...Shape...Select Shape or Void/Cavity....Then select your shape and stretch it or move corners.  You may also use the Edit/Vertex command.  Note:  This does not work on Circles.  Hope that works for you.
    Ken
  • DrLightning
    Thanks. This will work slowly, where I have to drag each edge. I tried doing a rectangular select to grab multiple edges and stretch them, but couldn't get anywhere. Imagine a fat cross or plus sign. I want to select the right half, having a vertical select boundary running down through the middle, then stretch everything on the right rightward. Thus, the vertical portion of the object in the middle gets wider (fatter), with the right side extending correspondingly more to the right. That is, I select the right half using a rectangular area and stretch everything inside that area to the right. Again, I can select edges and probably vertexes with the method you mentioned. But then I have to do it three times, once for each of my vertical edges (think of the cross). And the distance is critical, so I have to be very careful. I'd rather only be careful once. I have to repeat this for half a dozen overlapping areas. I really wish I could select multiple and stretch all of them with one grab. I could do this in Eagle, I believe.
  • KEN13
    Dr.
        I understand completely what you want to do, however I do not know if that can be done.  If I figure something out I will let you know.  Sorry:(
    Ken
  • redwire
    redwire over 15 years ago
     Not sure what the shape looks like but one thing you might try is to make a copy of the existing shape (keep the netname the same).  Move the copy over 0.100" and then merge the two shapes back together.  There may be some cases where this is not the best method but it is something you should try...
  • DrLightning
    Thanks for the suggestion, redwire. Please note that I did try this, but it appears that merge is not allowed on unfilled shapes, and my shapes are unfilled. You and I both can fathom a way to make this work -- assume the shape is filled, union the area, determine a new outline, realize the shape is not to be filled -- but then doing that would require good user interface design... Aside from wanting to know how for future more difficult tasks, note that it only took six edge stretches to accomplish my task (along with five wholesale moves of shapes totally enclosed within my desired stretch select area). I'll have to repeat for another board, but it's not a big ordeal.
