  3. Is the full featured EXTRACTA available in Orcad pcb designer...
  • Views 22164
Is the full featured EXTRACTA available in Orcad pcb designer standard?
Raull
Raull over 14 years ago
I have Hyperlynx for simulation but it requires EXTRACTA to convert a .brd Allegro file to a .hyp file.
Does anyone know if the full featured EXTRACTA is available in Orcad pcb designer standard?
The reason I ask is because I do not do any PCB design at all. Therefore I would like the lowest cost Cadence product to get EXTRACTA in my machine and Hyperlynx can do it's extraction.
Any tips will be appreciated.
Best regards
  • fxffxf
    fxffxf over 14 years ago
    The basic extracta exe callable at the OS level (e.g a DOS command window or XTerminal) is unlicense. For certain calculated properties, it may require the presence of some high level licenses to perform the calculation but I would say that for over 99% of extract-able properties no access to Cadence licenses is required. You do not need to license to install a Cadence product and pretty much any back-end product includes extracta exe.
    Of course,  this requires some knowledge to using a OS level command window and maybe leveraging bat files or perl scripts to allow automating of the design extraction. You would also need to know what view files are required.
  • fxffxf
