  3. Allegro Free Physical PCB viewer 16.5 problem
  • Subscribers 167
  • Views 17493
LeonidSjm
LeonidSjm over 14 years ago
I installed Allegro Free Physical viewer ver 16.5, but i can't see the menu bar on the top of the program.
All previous versions are work (16.2, 15.2).
What can be the problem?
I tried to reinstall several times, but it doesn;t help. It work on the other PC so the problem is with the PC but i don't know what.
Leonid
  • mcatramb91
    mcatramb91 over 14 years ago
    Here are a couple things to try:
    - Open the viewer and type the following on the command line:   reset dockwindows
              This will reset the toolbars and windows to Cadence default.
    - Close the viewer and rename your PCBENV Folder to a different name and reopen the viewer.  The PCBENV Folder is located in your Home directory (%HOME%)
              Sometimes version specific configuration is stored in the PCBENV Folder which may cause issues.
    Hope this helps,
    Mike Catrambone
    Plexus Engineering Solutions
  • TomWassick
    TomWassick over 13 years ago
     Am having the same problem, and neither solution works.  It happens with both 16.3 and 16.5 (but not 16.2) -- any other thoughts?
  • fxffxf
    fxffxf over 13 years ago
     From Windows Start menu find the allegr free viewer ote,. Instead of picking it do a RMB and pick Properties.
    Copy the Target: location value.
    From the Windows Run... menu item paste the the copied item and then add: -safe outside the ending double quotes.
    If this allows you to see the menu then something is wrong in your env.
  • TomWassick
    Thanks but still no menu....
    Seeing this in the command area:
    Starting new design...
    E- (SPMHGF-8): No command ID mapping files (allegro ) found in MENUPATH.
    Command >
  • fxffxf
    If the free viewer command area type: set
    With  the resulting window look for the lines with:
       menuload - which should a value of allegro_free_viewer
       menupath - in an "out of the box" environment it should have 3 entries:
                        . <cdsroot>/local/pcb/menus  <cdsroot>/share/pcb/text/cuimenus
    In a Windows file explorer navigate to the last entry shown in menupath. If you don't see the following file names then you have a problem with with installation hierarchy you have OS level environment variables that is toasting your viewer. Files are:
          allegro_free_viewer.men
          allegro.r2c
