  3. Allegro Free Physical PCB viewer 16.5 problem
  • Subscribers 167
  • Views 17495
LeonidSjm
LeonidSjm over 14 years ago
I installed Allegro Free Physical viewer ver 16.5, but i can't see the menu bar on the top of the program.
All previous versions are work (16.2, 15.2).
What can be the problem?
I tried to reinstall several times, but it doesn;t help. It work on the other PC so the problem is with the PC but i don't know what.
Leonid
  • mcatramb91
    mcatramb91 over 14 years ago
    Here are a couple things to try:
    - Open the viewer and type the following on the command line:   reset dockwindows
              This will reset the toolbars and windows to Cadence default.
    - Close the viewer and rename your PCBENV Folder to a different name and reopen the viewer.  The PCBENV Folder is located in your Home directory (%HOME%)
              Sometimes version specific configuration is stored in the PCBENV Folder which may cause issues.
    Hope this helps,
    Mike Catrambone
    Plexus Engineering Solutions
