  3. Can't find last four wires that need to be routed.
  • Views 1034
DrLightning
DrLightning over 15 years ago
I'm almost done with this board, but can't find the last four wires that need to be [manually] routed. I set to "fix" all my connect lines, vias, and symbols. Then I run autoroute. It accomplishes nothing, but says 4 wires remain to be routed. When I next super filter to ratsnest and draw a selection box around the whole board, software says "No Element Found". This is inconsistent. How do I find the 4 wires that need to be routed, or is the autorouter deceiving me? Note when I turn all layers off in the past, I can see the remaining ratsnest. I see nothing now. I noticed earlier that I wasn't getting blue ratsnest lines for unconnected Gnd signal. Could I have four unconnected grounds, and some config is causing them not to show as ratsnest????
  • DrLightning
    Found http://www.cadence.com/Community/forums/p/15263/52486.aspx Used Tools / Reports / Unconnected Pins
  • edhickey
    edhickey over 15 years ago
    You can also open the Display - Status dialog and click the colored box adjacent to Unrouted Connections to obtain the status report.
