  3. Cross-probing between Capture and Allegro
  • Subscribers 163
  • Views 16665
PCB George
PCB George over 14 years ago
 I have made the switch to 16,5, and I am about ready to to go back to 16.3. :@
 I used to be able to highlight a part in Allegro and have it "highlight" in Captur, but once I loaded 16.5 thyat all went away :(  Same with placing a part in Allegro by clicking it in Capture.
 I have turned on the Enable Intertool Communications option in Capture,do I have to set a variable in Allegro?
  • steve
    steve over 14 years ago
    There is no setting in Allegro. You might want to try re-creating the netlist and then import into Allegro. Also make sure you are on the latest Hotfix.....
  • PCB George
    That worked, thanks :)
    George
