  3. Re: RE: Can't generate netlist for pcb editor (allegro 16...
  • Subscribers 163
  • Views 333
Re: RE: Can't generate netlist for pcb editor (allegro 16.0)
CAT8024
CAT8024 over 14 years ago
Thank you for the reply. On Thu, September 29, 2011 17:38, mvonahnen wrote: > > It took a serious of things to get mine working. I disabled my virus > scanner (not just for install) which makes my IT queezy. I removed and > reinstalled the software and then there are a couple items to do > concerning registering .dll's in an app note. All worked fine until I > came in one morning to find out that Microsoft updated Windows 7 and then > I had problems again. > I ended up reverting Windows 7 back and it worked again. There is still > something going on with the SW, but if I don't let Windows 7 update, it > seems to be stable. > Oh by the way, still have the problem with 16.5 > > -- > View this message online at: > www.cadence.com/.../1301330.aspx > -- > You received this email because you subscribed to notifications for the > Cadence PCB Design Forum. To unsubscribe, log in, go to forums, and change > your forum subscriptions. > > www.cadence.com/.../ForumSubscriptions.aspx
