  3. Export an ascii file from the .dsn file of orcad
  • Subscribers 163
  • Views 16504
HSID
HSID over 14 years ago
I am using Orcad schematic capture version 10.5. A vendor we are about to use does not use Orcad for schematic capture. Is there a way to export out the design or another export command which they could use. I know I can export out the netlist in an ascii format but I believe they want to re-create the schematic in thier software package which is the Mentor graphics schematic capture software.
HS
  • redwire
    redwire over 14 years ago
     Have you considered EDIF format?
  • HSID
    I have found out from my vendor that the ascii file he needs is not of the schematic design but a pick and place report generated from the pcb layout. Thanks for the help anyway.
    HS
