  3. Is there a way to import stack-up xls file into cross section...
  • Views 14922
Is there a way to import stack-up xls file into cross section?
package design
package design over 14 years ago
With Regards,
Subbu
44262304
  • Khurana
    Khurana over 14 years ago
    I have never done this but try to see if you can create XML from your XLS (there are videos on YouTube for this) and then read in the XML file...if you've the time then a simple script can be created to convert XLS into XML for import into Cadence.
  • Khurana
