  3. EMI/EMC
  • Views 2565
EMI/EMC
KARPCB
KARPCB over 14 years ago
Dear Friends what are the main reason to occur EMI/EMC problems in pcb layout? how to identifiy that problems(EMI) i have been using allegro 16.3? how to reduce emi in pcb layout?
  • KoolKat
    KoolKat over 14 years ago
    Here is something for you to reference.
    http://www.cvel.clemson.edu/emc/FAQ/question-pcbdes01.html
    And, of course, if you do an internet search on "emi and emc in printed circuit boards" you will get many good references.
  • Mike Veal
    Mike Veal over 14 years ago
    EMI and SI go hand in hand. High speed nets will radiate when the return current in the power plane and the signal current in the net form a loop. The greater the di/dt, the smaller the loop needs to be to stop radiation. Rapid changes in impedance such as 90 degree corners in high speed nets can also bleed radiation.
    I thoroughly recommend attending Howard Johnson's course, Signal Integrity, Black magic. No connection other than a happy attendee.
  • KARPCB
    thanks for your information i dont know about howard johnsons course, please guide me.
  • Mike Veal
     This fella :
    http://www.signalintegrity.com/
    The seminar I was referring to was high speed digital design - an intro to black magic. The book is good as a reference manual, but  a little dry to read on its own.
