  3. SMD footprints for wave soldering
  • Views 14794
Carvey
Carvey over 14 years ago
Hello
We want to mount SMD components on the bottom side of board that would be wave soldered.
Will the same SMD footprints used on the top side work on the bottom?
  • GraF
    GraF over 14 years ago
    You've to look at IPC-2222 standard and related documents in order to buil a reliable footprint for each SMD which you need to wave-soldering. Perhaps it seems good using the same footprint of reflow but it's not so good speaking of big numbers of components to be mounted.
    BR
  • GraF
    BR
