  3. Script [File>Script] - Allegro 16.5
  • Views 1879
KoolKat
KoolKat over 14 years ago
In the past, I would call a simple script with the command "rs" now this requires "replay."   Is this a change, or was it that at my previous employers it was user defined as "rs"?  Is it possible to change the script call to "rs" or something shorter than "replay"?
Also, I have searched several Cadence references without success to see how I can set a path so that these simple scripts are saved and read from a central location on the network rather than pulled into the local design project to be used.  It's probably very easy to set this up but I can't seem to find the answer to setting this up.
Thanks in advance for any help!
  • djhutchi
    djhutchi over 14 years ago
    I’m guessing your previous employers had a simple command alias of alias rs replay
    The Allegro environmental variable scriptpath sets the search path for scripts.
  • redwire
    redwire over 14 years ago
     It's always been replay so your previous employer must have had an alias set up.  You can do the same:
    alias rs replay
  • KoolKat
    Thanks djhutchi and redwire.
    That's it!  Ironically, two different companies that I worked for both used "rs" as the alias.
     Thanks again.
