  3. rpc server not available
  • Views 14883
Lionking
Lionking over 14 years ago
Hello, all.
I have installed the Cadence 16.3. and it worked well.
Several days later I launched Visual studio 2008 and came the problem. In capture, I want to put two VSTIM in SOURCSTM library. When I use the option " edit-pspice stimulus ", it gave me the message that "Only one instance of the Stimulus Editor is allowed to run. Please close the other instance before starting another one.". and if I want close the capture, it gave me another message:" rpc sever is not available."
I am not good at computer, so hope you can give more detailed things.
Since I am not from english speaking country, hope you can understand and I would appreciate any help from you.
  • Alok Tripathi
    Alok Tripathi over 14 years ago
    What is sub-product version (patch/ISR version) you are using? You can find this from Help>About Dialog of Capture.
    When you got the message "..Only one instance of the Stimulus Editor ..." were one instance of stm editor already running?
    This problem should go away on exit & relaunch of capture? Can you confirm this?
  • bhushana
    bhushana over 12 years ago
    I am using 16.0 cadence. For particular test case in the project(design entry cis) I get the rpc error, simserver error, file doesn't exist errors.
    Please help me on this asap.
    Cadence, please fix this type of bugs in the software and documentation of software is not correctly composed in  the help section.
    Bhushan
