  3. How to preselect Checkplus rules for different teams
  • Subscribers 163
  • Views 14107
Samuel Zhang
Samuel Zhang over 14 years ago
 Hi everyone,
I have a problem about Checkplus,  according to Solution 11223356, everyone who is pointing to the cds_site will have the selections set as their default. If I want different teams use different '.ini' files, for example, team1 use 'checkplus_t1.ini', team2 use 'checkplus_t2.ini', how can I do it? and how to active the Checkplus as per different '.ini' files in batch mode? Can we directly use the command to invoke it in Concept HDL window?
Is there anyone can help me? Thanks very much
  • Samuel Zhang
    When I add multiple envs( precompiled_logic.rle, logical_env.rle, physical_env.rle) into the cp.dat at the same time and run checkplus in batch mode, a message prompts "Error ![4108] Cannot load more than one enviroment in a single run". How to allow all those envs exist in the cp.dat, then I can run the selected rules at one time? In interactive mode, we can select graphical rules, logical rules and physical rules at the same time, in batch mode, can we do this?
