  3. .5 mm BGA package breakout
  • Views 13650
CADcaveman
CADcaveman over 14 years ago
Curious to see how everyone is routing these fine pitch BGA packages.
the ball pads are 0.010 and that leaves a 0.0097 gap between pads.
So normal pad w/o dogbone required    0.010
so to breakout of the inner rows on the surface layer
Pitch 0.5 mm                      0.0197
Yields gap                            0.0097
4/4/4 would require .012, so 0.0097 allows only 3.2/3.2/3.2
 the 3.2/3.2/3.2 is not manufacturable in volume production.
So with a pad elongated, 12.5 x 7.5, leaves gap 0.0122, which is adequate for 4/4/4
Note 12.5 x 7.5 is slightly bigger area then 0.010 pad
 Has any one had any experience with this type of approach or any other approach other than HDI type routing where you use blind burried vias?
Thanks in advance for all help
  • budnoel
    budnoel over 14 years ago
    Hi Caveman - I'm not an expert but I thought you might find some help in a few articles I have that address this subject.  If you would like, I could email them to you.  Simply send me your off-line email address if you're interested.
  • CADcaveman
    ctm053062@yahoo.com Thanks!
