  3. changing component origin
  • Replies 7
  • Views 17846
dv4321
dv4321 over 14 years ago
Hi
can we change component origin without changing the symbol itself
  • budnoel
    budnoel over 14 years ago
    If you open the component in PCB Editor (the *.dra file) you can simply change the origin in the same way that you would change it in a .brd file.
  • oldmouldy
    oldmouldy over 14 years ago
    Setup>Design Parameters, Design tab, Move Origin group, specify the new X and Y location for the origin. You might find it useful to get the required location from a "Show Element" for the required origin.
  • dv4321
    Thanks.
    But I want to know if in PCB editor we can change origin – without changing the dra file.
  • budnoel
    I don’t believe that is possible.   I’m pretty sure you can only change it in the .dra file.  I believe origin changes in the .brd file will relate to the board origin only.
    Bill Noel
  • oldmouldy
    No, the component, symbol, origin is stored in the DRA file and compiled to the relevant ?SM file. You will need to change the DRA file. IF you have a BRD file and not the Libraries, use File>Export>Libraries to get the library files dumped to a directory - I recommend using a new, empty, directory to dump the files to. Use Place>Update Symbols to get the symbol(s) replaced after modification.
