  3. Unable update the padstack
  • Views 14254
AmyZhang
AmyZhang over 14 years ago
I want to change an irregular pad’s size and revised the shape symbol firstly, then update the padstack in the .dra file it dosen’t work, only if the shape symbol is saved as another file and used in the pad designer again, it would be work, why?
  • steve
    steve over 14 years ago
    In the dra file use Tools - Update Symbols, then check the shape and flash symbols and click on refresh......
  • Ago8
    Ago8 over 14 years ago
    Hello,,
    I got problem when check the shape and flash symbol,,
    "shape and flash symbol" is not selectable, so i can't check it,,
    and yes, it is a problem, the symbol i've modified can't viewed in PCB editor,,
    first i export the libraries from PCB editor, then i open package editor and editing some package symbol, and the problem just like i wrote above.
    Thankyou.
