  3. Rectangular Pads
  • Views 15763
Rectangular Pads
Babar
Babar over 14 years ago
Hi All,
 I have a problem related to rectangular pads in orcad 10. The problem is how to get drill (cut) to rectangular pad in rectangular shape(Vertical y-axis) as the orcad supports only round drills. The part is from OMRON i.e. LY2N with Mouser part Number 653-LY2N-AC220-240. I need your suggestions or proposed solution.
 Thanks in advance.
  • steve
    steve over 14 years ago
    Orcad Layout (v 10) is a very old tool and does not let you add slots for drills. You could update to PCB Editor (which can add a slots) or draw something manually around the circle drill (as the centre) and add a note for the fabricator to slot this.
  • steve
