  3. Having a problem with simulating a comparator
  • Views 16685
maxwellc
maxwellc over 14 years ago
 Hello all,
 I've followed the standard steps in creating a part to use for simulation from a manufacturer-provided SPICE file. However, I am running into errors that state "Extra text on line" and "Invalid number", although I have changed nothing from the provided SPICE file. Can someone take a look and see where the problem may be? I've attached the SPICE file for reference (please note that I changed the file type from .txt to .lib before using Model Editor).
Note from Moderator - the attachment violated copyrighted material, so has been removed. Instead you can download it from here.
**** 12/15/11 10:55:48 ******* PSpice Lite (April 2011) ******* ID# 10813 ****
 ****     CIRCUIT DESCRIPTION
** Creating circuit file "Test Pulse.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
.LIB "../../../comparator adcmp601.lib"
* From [PSPICE NETLIST] section of C:\OrCAD\OrCAD_16.5_Lite\tools\PSpice\PSpice.ini file:
.lib "nomd.lib"
*Analysis directives:
.TRAN  0 5ms 0
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source TEST PULSE
X_U1         N00193 N00186 5 +5V 0 1 ADCMP601
V_V1         N00193 0
+SIN 2.5 1 50K 0 0 0
V_V2         N00186 0 DC 2.5
V_V3         +5V 0 DC 5
**** RESUMING "Test Pulse.cir" ****
.END
INFO(ORPSIM-15423): Unable to find index file "comparator adcmp601.ind" for library file "comparator adcmp601.lib".
INFO(ORPSIM-15422): Making new index file "comparator adcmp601.ind" for library file "comparator adcmp601.lib".
Index has 16 entries from 1 file(s).
**** EXPANSION OF SUBCIRCUIT X_U1 ****
X_U1.c0 X_U1.17 0 5e-13
X_U1.c1 X_U1.19 0 2e-13
X_U1.c2 N00193 0 2e-13
X_U1.c3 N00186 0 2e-13
X_U1.dp 0 +5V X_U1.DESD
X_U1.e0 X_U1.18 0 X_U1.17 0 4 X_U1.e0 0.3
ERROR(ORPSIM-16371): Extra text on line
+ min -0.3
X_U1.e1 X_U1.20 0 X_U1.19 0 1 X_U1.e1 0.3
**** EXPANSION OF SUBCIRCUIT X_U1.xb ****
X_U1.xb.d0 X_U1.xb.201 X_U1.xb.202 X_U1.xb.DSIM1
X_U1.xb.d1 X_U1.xb.201 X_U1.xb.203 X_U1.xb.DSIM1
X_U1.xb.d2 X_U1.xb.205 X_U1.xb.206 X_U1.xb.DSIM1
X_U1.xb.d3 X_U1.xb.202 X_U1.xb.204 X_U1.xb.DSIM1
X_U1.xb.d4 X_U1.xb.203 X_U1.xb.204 X_U1.xb.DSIM1
X_U1.xb.d5 X_U1.xb.207 X_U1.xb.208 X_U1.xb.DSIM1
X_U1.xb.e0 X_U1.xb.203 0 X_U1.13 0 1
X_U1.xb.e1 X_U1.xb.202 0 X_U1.12 0 1
X_U1.xb.e2 X_U1.xb.205 0 X_U1.xb.201 0 1
X_U1.xb.e3 X_U1.xb.208 0 X_U1.xb.204 0 1
X_U1.xb.e4 X_U1.xb.210 0 +5V X_U1.xb.209 1 X_U1.xb.e4 1.6
+ min 0.6
X_U1.xb.e5 X_U1.xb.219 0 X_U1.xb.211 X_U1.xb.207 5 X_U1.xb.e5 1
+ min 0
X_U1.xb.g0 0 +5V X_U1.xb.212 X_U1.xb.213 0.0015 X_U1.xb.g0 0.0003
+ min 0
X_U1.xb.g1 X_U1.15 0 X_U1.xb.212 X_U1.xb.213 0.001 X_U1.xb.g1 0.0002
+ min 0
X_U1.xb.g2 X_U1.16 0 X_U1.xb.214 X_U1.xb.215 0.001 X_U1.xb.g2 0.0002
+ min 0
X_U1.xb.g3 X_U1.16 0 X_U1.xb.214 X_U1.xb.216 -0.001 X_U1.xb.g3 0
+ min -0.0002
X_U1.xb.g4 0 X_U1.14 poly 2 X_U1.xb.219 X_U1.xb.220 X_U1.xb.217
+ X_U1.xb.218 0 0 0 0 0.002 max
ERROR(ORPSIM-16152): Invalid number
+ 1e-4 min 0 g5
+ 6 5 poly 2 219 220 217 218 0 0 0 0 0.002 max 5e-05 min 0 i0
+ 0 201 dc 0.001 i1
+ 204 0 dc 0.001 i5
+ 206 0 dc 0.001 i6
+ 0 207 dc 0.001 r0
+ 206 218 1 r1
+ 220 0 1 v0
+ 209 0 dc 1.9 v1
+ 211 0 dc 1.6 v2
+ 217 210 dc 0.2 v3
+ 212 207 dc 0.025 v4
+ 213 0 dc 1.6 v5
+ 214 207 dc 0.025 v6
+ 215 0 dc 0.6 v7
**** EXPANSION OF SUBCIRCUIT X_U1.xh ****
X_U1.xh.c0 X_U1.xh.410 X_U1.xh.409 3.4e-11
X_U1.xh.c1 X_U1.xh.401 0 1e-12
X_U1.xh.d0 0 X_U1.xh.404 X_U1.xh.DSIM1
X_U1.xh.d1 X_U1.xh.401 5 X_U1.xh.DSIM3
X_U1.xh.e0 X_U1.xh.402 X_U1.xh.405 X_U1.xh.405 X_U1.xh.403 1
X_U1.xh.e1 X_U1.xh.412 0 X_U1.17 0 20 X_U1.xh.e1 0.3
+ min -0.3
X_U1.xh.f1 +5V 0 X_U1.xh.v1 7 X_U1.xh.f1 0.0007
+ min 0
X_U1.xh.f2 0 0 X_U1.xh.v2 8 X_U1.xh.f2 0.0008
+ min 0
X_U1.xh.g0 X_U1.xh.408 X_U1.17 X_U1.xh.410 X_U1.xh.409 0.01
+ X_U1.xh.g0 0.0003
+ min -0.0003
X_U1.xh.g1 X_U1.xh.411 0 X_U1.xh.414 0 0.01 X_U1.xh.g1 3e-4
+ min 0
X_U1.xh.h0 X_U1.xh.413 0 X_U1.xh.v0 1000 X_U1.xh.h0 0.030
**** EXPANSION OF SUBCIRCUIT X_U1.xo ****
X_U1.xo.c0 1 X_U1.xo.507 8.8e-13
X_U1.xo.c2 X_U1.xo.505 X_U1.xo.504 6e-14
X_U1.xo.c3 X_U1.xo.503 X_U1.xo.504 6e-14
X_U1.xo.d0 X_U1.xo.504 X_U1.xo.503 X_U1.xo.DSIM2
X_U1.xo.d1 X_U1.xo.505 X_U1.xo.504 X_U1.xo.DSIM2
X_U1.xo.d2 X_U1.xo.506 X_U1.xo.505 X_U1.xo.DSIM1
X_U1.xo.d3 X_U1.xo.503 X_U1.xo.501 X_U1.xo.DSIM1
X_U1.xo.e0 X_U1.xo.506 0 X_U1.xo.508 0 1
X_U1.xo.e1 +5V X_U1.xo.501 X_U1.xo.502 0 1
X_U1.xo.e2 X_U1.xo.507 0 +5V 0 0.5
X_U1.xo.g0 0 X_U1.xo.505 X_U1.21 0 -0.0042667 X_U1.xo.g0 0.00032
+ min -0.00032
X_U1.xo.g1 X_U1.xo.503 0 X_U1.21 0 0.0042667 X_U1.xo.g1 0.00032
+ min -0.00032
X_U1.xo.g2 +5V 0 X_U1.21 0 -0.0085333 X_U1.xo.g2 0.00064
+ min 0
X_U1.xo.g3 0 0 X_U1.21 0 0.0085333 X_U1.xo.g3 0.00064
**** EXPANSION OF SUBCIRCUIT X_U1.xv ****
X_U1.xv.e0 X_U1.xv.302 0 X_U1.13 0 1
X_U1.xv.e1 X_U1.xv.304 0 X_U1.12 0 1
X_U1.xv.g0 X_U1.17 0 poly 1 X_U1.xv.303 0 0 1.71e-06 -3.3e-07 max
+ 3e-06 min -1e-06 g1
+ 2 0 4 301 6.667e-07 max 2e-06 min 0 r0
+ 302 303 1000 r1
+ 303 304 1000 v0
  • oldmouldy
    oldmouldy over 13 years ago
    Almost certainly due to having a circuit node(s) named +5V, + is a reserved character in SPICE, and therefore PSpice, for "add" or "continuation", name your node VCC, or similar, and assign a 5V source to it. See page 82 of the pspug.pdf in the doc\pspug directory of the installation for assigning of Net Alias.
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    ADCMP601 model is not compatible with PSpice syntax. it seems that this model has been designed as per HSPICE syntax. You need to change this to work for PSpice. E & G devices syntax are not as per PSpice syntax and these needs to be changed. You need to get rid of max & min limit, where ever applied in model. With this change I believe you should be able to get it simulated in PSpice.
    Example
    Line "g3 0 2 21 0 0.0085333 max=0.00064 min=0"
    should be g3 0 2 21 0 0.0085333 ;max=0.00064 min=0
    or g3 0 2 21 0 0.0085333
  • maxwellc
    maxwellc over 13 years ago
     Thanks, I am not very familiar with SPICE syntax so it didn't immediately occur to me that it was an HSPICE model. I will give that a try. I'd also like to thank the moderator for linking to the SPICE model, and next time I'll link to them instead of attaching them.
