  3. dbdoctor error ,thanks
  • Replies 8
  • Subscribers 167
  • Views 29951
lsuestc
lsuestc over 13 years ago
In my project, cy7c68013 is used. The cy7c68013 pcb project is downloaded from the cypress website. But cannot open it with candence allegro spb 16.2 pcb editor.  When i take dbdoctor for updating ,the error occours :
Performing UPREV on the database - F:/打包/CY3684_A_Layout.brd
   Performing dbfix13 to bring DB up to REV13
ERROR: Revision to REV13 found errors.
   Performing dbdoctor14 to bring DB up to REV14
ERROR: Revision to REV14 found errors.
   Performing dbdoctor15 to bring DB up to REV15
ERROR: Revision to REV15 found errors.
ERROR: Uprev failed!
CY3684_A_Layout.zip
  • davidsun
    davidsun over 13 years ago
    don't understand what Internet Explorer did for the post, so I attached the dump as a file,
    have a nice day,
    • spm0240b1_dump.txt
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    My best guess is that it is the spaces in the directory where you run dbdoctor (although in 16.5 it works with spaces).
    Try putting the files in c:\temp and run dbdoctor from there?
    I also forgot to mention that you can run dbdoctor *.pad and dbdoctor *.dra to update many padstacks/footprints in the same directory.
    Best regards
    Ole
  • Raviteza
    Raviteza over 13 years ago
    Dear Sir,
                 Pls help me to uprev the attached ti IC footprint files to cadence 16.5. I am unable to do it.
    Thanks in Advance
    ti_footprints_ICs.zip
