  3. dbdoctor error ,thanks
  • Replies 8
  • Subscribers 166
  • Views 32426
lsuestc
lsuestc over 14 years ago
In my project, cy7c68013 is used. The cy7c68013 pcb project is downloaded from the cypress website. But cannot open it with candence allegro spb 16.2 pcb editor.  When i take dbdoctor for updating ,the error occours :
Performing UPREV on the database - F:/打包/CY3684_A_Layout.brd
   Performing dbfix13 to bring DB up to REV13
ERROR: Revision to REV13 found errors.
   Performing dbdoctor14 to bring DB up to REV14
ERROR: Revision to REV14 found errors.
   Performing dbdoctor15 to bring DB up to REV15
ERROR: Revision to REV15 found errors.
ERROR: Uprev failed!
CY3684_A_Layout.zip
  • Ejlersen
    Ejlersen over 14 years ago
    Hi
    dbdoctor works fine for 16.5 - I've downreved the data to 16.2 and attached.
    Happy New Year
    Ole
    CY3684_A_Layout_162.zip
  • lsuestc
    thanks very much!
  • davidsun
    davidsun over 14 years ago
    Hi Ole
    Could you please help me dbdoctor the attached file. it is a BGA package for TI MSP430F5438A. I have a 16.2 orcad PCB eidtor, but it won't work.
    Best Regards,
    David Sun
    zqw113_allegro.v13.6.zip
  • Ejlersen
    Hi
    I've updated it to 16.5 - you will need to download a lite edition or upgrade your license to get it to work.
    I would however still expect dbdoctor 16.2 to work.
    All I do is the following
    1. unzip files to a directory
    2. start a command prompt in that directory
    3. type dbdoctor xxx.pad
    4. type dbdoctor xxx.dra
    That's it
    Best regards
    Ole
    zqw113_allegro.v16.5.zip
  • davidsun
    Hi Ole Thank you for your kindly replay, here is the dump from command prompt. I don’t want to waste you too much time to solve this problem, just let you the result. I am learning Orcad tools. I hope I did everything correct. it is not a big deal if I couldn’t get this converted.  I will ask my boss to upgrade the tools.Appreciate your help. David  Microsoft Windows XP [Version 5.1.2600](C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\dsun\My Documents\zqw113_allegro>dbdoctor spm0240b1.padPerforming UPREV on the database - C:/Documents and Settings/dsun/My Documents/zqw113_allegro/spm0240b1.pad   Performing dbfix13 to bring DB up to REV13    Performing dbdoctor14 to bring DB up to REV14    Performing dbdoctor15 to bring DB up to REV15 error in open drawing = 32000016Uprev failed! See C:/Documents and Settings/dsun/My Documents/zqw113_allegro/spm0240b1.log.Done dbdoctorSymInit: Symbol-SearchPath: '.;C:\Documents and Settings\dsun\My Documents\zqw113_allegro;C:\OrCAD\OrCAD_16.2\tools\pcb\bin;C:\WINDOWS;C:\WINDOWS\system32;SRV*C:\websymbols*http://msdl.microsoft.com/download/symbols;', symOptions: 530, UserName: 'dsun' OS-Version: 5.1.2600 (Service Pack 3) 0x100-0x1 C:\OrCAD\OrCAD_16.2\tools\pcb\bin\dbdoctor.exe:dbdoctor.exe (00400000), size: 9150464 (result: 0), SymType: '-exported-', PDB: ''C:\WINDOWS\system32\ntdll.dll:ntdll.dll (7C900000), size: 729088 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.6055nC:\WINDOWS\system32\kernel32.dll:kernel32.dll (7C800000), size: 1007616 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5781nC:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCR80.dll:MSVCR80.dll (78130000), size: 634880 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 8.0.50727.6195nC:\WINDOWS\system32\msvcrt.dll:msvcrt.dll (77C10000), size: 360448 (result: 0),SymType: '-exported-', PDB: '', fileVersion: 7.0.2600.5512nC:\OrCAD\OrCAD_16.2\tools\bin\cdn_xerces-c_2_7.dll:cdn_xerces-c_2_7.dll (12000000), size: 1896448 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 2.7.0.0nC:\WINDOWS\system32\WS2_32.dll:WS2_32.dll (71AB0000), size: 94208 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5512nC:\WINDOWS\system32\ADVAPI32.dll:ADVAPI32.dll (77DD0000), size: 634880 (result:0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5755nC:\WINDOWS\system32\RPCRT4.dll:RPCRT4.dll (77E70000), size: 602112 (result: 0),SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.6022nC:\WINDOWS\system32\Secur32.dll:Secur32.dll (77FE0000), size: 69632 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5834nC:\WINDOWS\system32\WS2HELP.dll:WS2HELP.dll (71AA0000), size: 32768 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5512nC:\WINDOWS\system32\COMCTL32.dll:COMCTL32.dll (5D090000), size: 630784 (result:0), SymType: '-exported-', PDB: '', fileVersion: 5.82.2900.6028nC:\WINDOWS\system32\GDI32.dll:GDI32.dll (77F10000), size: 299008 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5698nC:\WINDOWS\system32\USER32.dll:USER32.dll (7E410000), size: 593920 (result: 0),SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5512nC:\WINDOWS\system32\WSOCK32.dll:WSOCK32.dll (71AD0000), size: 36864 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5512nC:\WINDOWS\system32\comdlg32.dll:comdlg32.dll (763B0000), size: 299008 (result:0), SymType: '-exported-', PDB: '', fileVersion: 6.0.2900.5512nC:\WINDOWS\system32\SHELL32.dll:SHELL32.dll (7C9C0000), size: 8482816 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 6.0.2900.6242nC:\WINDOWS\system32\SHLWAPI.dll:SHLWAPI.dll (77F60000), size: 483328 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 6.0.2900.5912nC:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCP80.dll:MSVCP80.dll (7C420000), size: 552960 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 8.0.50727.6195nC:\WINDOWS\system32\NETAPI32.dll:NETAPI32.dll (5B860000), size: 348160 (result:0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.6260nC:\WINDOWS\system32\VERSION.dll:VERSION.dll (77C00000), size: 32768 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5512nC:\WINDOWS\system32\IMM32.DLL:IMM32.DLL (76390000), size: 118784 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5512nC:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll:comctl32.dll (773D0000), size: 1060864 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 6.0.2900.6028nC:\WINDOWS\system32\dbghelp.dll:dbghelp.dll (59A60000), size: 659456 (result: 0), SymType: '-exported-', PDB: '', fileVersion: 5.1.2600.5512n <<< STACK TRACE >>>00A6BF62 (dbdoctor): (unknown file): (unknown function)00A6CACD (dbdoctor): (unknown file): (unknown function)00A5DD09 (dbdoctor): (unknown file): (unknown function)00A33AB1 (dbdoctor): (unknown file): (unknown function)004023D6 (dbdoctor): (unknown file): (unknown function)00402EEC (dbdoctor): (unknown file): (unknown function)7C817077 (kernel32): (unknown file): RegisterWaitForInputIdle C:\Documents and Settings\dsun\My Documents\zqw113_allegro>  Log file   Performing UPREV on the database - C:/Documents and Settings/dsun/My Documents/zqw113_allegro/spm0240b1.pad   Performing dbfix13 to bring DB up to REV13 C:\Documents and Settings\dsun\My Documents\zqw113_allegro>echo off  ERROR: Revision to REV13 found errors.   Performing dbdoctor14 to bring DB up to REV14 C:\Documents and Settings\dsun\My Documents\zqw113_allegro>echo off  ERROR: Revision to REV14 found errors.   Performing dbdoctor15 to bring DB up to REV15 C:\Documents and Settings\dsun\My Documents\zqw113_allegro>echo off  ERROR: Revision to REV15 found errors.ERROR: Uprev failed!
