  3. re-load SPICE results and update the voltage source
  • Views 13715
Sohrab
Sohrab over 13 years ago
I have a DC voltage source VN connected a network of components.
I want to run the spice simulation for t=10 seconds and save the results.
but later, I want to load this circuit exactly as it was at t=10 (every voltage, current, everything the same, as if the simulation was not ever stopped), change the value of VN, and resume the simulation.
 Is this thing possible?
  • oldmouldy
    oldmouldy over 13 years ago
    Take a look at Checkpoints, see "Using Checkpoints" page 536 of the PSpice Users Guide, pspug.pdf in the doc\pspug directory of the installation.
  • Sohrab
    Thanks for the quick reply.
    Checkpoints work, but changing the voltage source has no effect. apparantly excitations can not be changed using this method. any suggestions?!
  • Sohrab
     doesn't work with VDC, but with VPULSE and VPWL:)
    Thanks again
