  3. Unable to see changes to PCB in real time
  • Views 14276
waldo15
waldo15 over 14 years ago
Hi all,
I am having quite a puzzling bevahoir withmy 16.3 Allegro PCB editor. Whenever I open my board file and I try to do any changes to it, i.e. move a component or route a net, I do no see the changes happen in real time.
Normally, when I was working with a PCB, I could select parts and move them about dynamically, i.e. I’d click on a part, then the part attaches itself to the cursor until I click again where I want the part placed. I can see the part move wherever I move the cursor which of course makes placing it an easy task. This time around, I cannot do that! I can click Move, then select the part, but the part itself does not attach to the cursor however the command is effective (as I can read in the command editor window that the part X was selected). The part remains in its current location. Then if I click in the target destination, the part will be moved but I have to press F5 to see the part effectively change placement to this new location.
Same thing happens when I try to route any single net.
I am running SPB 16.3 on Win 7 64bit Enterpris.
  • MAAC
    MAAC over 14 years ago
     you need a dedicated graphics card(1GB or more) with win7 for proper view...disabling opengl will have issus with 3D viewer..
    if your using 16.3 then be on latest ISR as support for 16.3-win7 was thru ISRs.....
  • MAAC
