  3. BS170/PLP problem simulation
  • Views 2556
elnino85
elnino85 over 13 years ago
Hello
I tries to run simulate for a simple circuit with MOSFET BS170/PLP.
The simulate failed and I get this error message:
** Creating circuit file "4-schematic1-4.sim.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Program Files\Orcad\PSpice\PSpice.ini file:
.lib "C:\Program Files\Orcad\Capture\Library\PSpice\phil_fet.lib"
.lib "nom.lib"
*Analysis directives:
.DC LIN V_V1 0 6 0.1
.STEP LIN V_V1 0 6 0.1
.PROBE V(*) I(*) W(*) D(*) NOISE(*)
.INC ".\4-SCHEMATIC1.net"
**** INCLUDING 4-SCHEMATIC1.net ****
* source 4
X_M1         N00269 N00240 N00339 BS170/PLP
R_R1         N00210 N00240  10k
R_R2         0 N00339  1k
V_V1         N00210 0 0Vdc
V_V2         N00269 0 12
**** RESUMING 4-schematic1-4.sim.cir ****
.END
ERROR -- Subcircuit BS170/PLP used by X_M1 is undefined
I tried to add the file "phil_fet.lib", at the simulation setting, "as global" or "to design", nothing help.
how can I fix this problem?
I am using PSPICE 9.2.
Thanks a lot
Nir
  • Alok Tripathi
    Alok Tripathi over 13 years ago
    You may want to check, if phil_fet.lib is present at “C:\Program Files\Orcad\Capture\Library\PSpice\phil_fet.lib” and include “BS170/PLP” model definition.
    The model definition should be something like
    .SUBCKT BS170/PLP 1 2 3
    * 1=drain  2=gate  3=source
    Cgs  2 3 12.3E-12
    Cgd1 2 4 27.4E-12
    Cgd2 1 4 6E-12
    M1 1 2 3 3 MOST1
    M2 4 2 1 3 MOST2
    D1 3 1 Dbody
    .MODEL MOST1 NMOS(Level=3 Kp=20.78u W=9.7m L=2u Rs=20m Vto=2 Rd=1.186)
    .MODEL MOST2 NMOS(VTO=-4.73 Kp=20.78u W=9.7m L=2u Rs=20m)
    .MODEL Dbody D(Is=125f N=1.023 Rs=1.281 Ikf=18.01 Cjo=46.3p M=.3423
    +            Vj=.4519 Bv=60 Ibv=10u Tt=161.6n)
    .ENDS
