  3. Refdes reappearance and via soldermask problems
  • Replies 7
  • Subscribers 166
  • Views 16724
shangwu
shangwu over 14 years ago
Question 1:
I accidently deleted a REFDES (top silkscreen class) on a component.  How do I make it to appear again?  I unplaced the component and placed it again, but didn’t help.  I can of course manually type in the text, but it does not attach to the component.
I read the follwing response, but where do I find the "Component Attachment" command?
 http://www.orcad.com/forums/ShowPost.aspx?PostID=23258
Question 2:
How do I delete the soldermask of a via (underneath a chip)?  I displayed the soldermask only and tried deleting it, but it deletes the via itself.  I only want to get rid of the soldermask of that via.
Thanks.
  • girish
    girish over 14 years ago
     ANS1: Go to place-> updates smbols->select the package symbol [which redes you have deleted accidently] ->do refresh.
    ANS2:Its not possible to delete the soldermask on pad directly . Go to the Tools->padstack-<modify design padstack->slect via[which you want to delete soldermask]->edit padstack ->make soldermask top & bottom value to null.&  do file->update to design& save to file .
     Note that it will affect to all via's of same padstack name. If want to delete SM for some perticular  set of via's then use different naming for padstack .
    HTH
    Girish kumar
  • steve
    steve over 14 years ago
    For the soldermask point you can use Tools - Padstack - Replace then select the via in question, then check the Options menu and select Instance, This gives the via in question a new name and any edits will only affect this via. Then continue to edit as per Girish's comments.
  • shangwu
    Hi Girish,
    I tried refreshing the symbol, but it didn't work.  I even deleted the old symbol and replaced it, but still the same.
    The no mask via works though.  The only thing is that I can only replace all the vias or do one via at a time.
    Thanks.
  • girish
    Refreshing the symbol works here!
    * Have you selected the perticular symbol during refresh?
    *Recheck your library whether its having the refdes mark under REFDES/SILKSCREEN TOP class
    * If above steps not works then change the footprint name  ,update to schematic & import.
    If you are aware of skill files . Check in skill forum Mr.Steve posted some skill files [replace via]  using that you can replace group of vias by temp grouping . It works great I am using it .
    Girish kumar
  • steve
    There is another way to replace padstacks..... In general edit mode window select or RMB - selection set - select by polygon, double click to create the polygon, the vias will hi-light then RMB over any of the vias and choose Replace - Padstack - Selected Instances then pick the via name you want to use....
