  3. IREF Issue
  • Views 18703
IREF Issue
aasheth
aasheth over 14 years ago
How do I add page number(IREF so I can follow what page it is leading to) while adding off-page connector to cadence?
When I click on off-page connector, its only giving me option to add name and nothing for IREF
Thanks!!
  • girish
    girish over 14 years ago
     Check Tools->Intersheet references option in Orcad capture
    Girish
  • vin5488
    vin5488 over 14 years ago
    Go to the file hierarchy right click on the page1 schematic or the schematic page then click on annotate. In that window click on Add Intersheet reference then click ok. Then again you will get another window there click on Off page connectors after doing this click ok. Regards, Vinay
  • aasheth
     @Girish: Unter Tools, The only message I get is to customize it....I could not go toInternal Reference page
     @Vinay: What do you mean by file hierarchy? I tried to right click on the schematic page and it didnt give me option to annoate. Also, under file, there wasnt any of that option.
    I am using Cadence 16.5 if that helps.
    I would appreciate if you guys can reply. Thanks.
     Akash
  • oldmouldy
    oldmouldy over 14 years ago
    Go to the Project Manager Window, select the DSN file within that window, then Tools>Annotate. IF you have a Schematic Page as the currently active item, Tools>Customize... will be the only Tools option.
