  3. Autosilk difficulties
  • Views 14372
calars
calars over 14 years ago
 I am using the Autosilk functionality in Orcad PCB Designer 16.5.  The problem I am having is I have several eletrolytic capacitors that have a silkscreen circle to mark the positive side; however, when I use the Autosilk utility it does not seem to translate over.   I have tried placing this circle on several of the board layers to no avail, it seems that the Autosilk function does not like shapes.  Any suggestions?
Thanks in advance
  • steve
    steve over 14 years ago
    Currently shapes are not a supported item by the Autosilk. You have two options. Add the shape circles in manually afterwards (you can add shapes to the layer). Or change the shape circles to a circular line with a line width. I also suggest you raise an enhancement SR with Cadence for them to support this feature.
  • steve
