  3. Way to vary pulse width of VPULSE
  • Views 17662
SysEngr
SysEngr over 14 years ago
I'm using Orcap Capture CIS Lite tool version 16.5. I need a part that generates pulses and allows us to vary the pulse width. I did use VPULSE part and it generates a pulse with fixed duty cycle. Is there a way to vary the pulse width? If yes how? If not is there another part to use?
  • Alok Tripathi
    Alok Tripathi over 14 years ago
    Yes, you can vary pulse width of vpulse source. You can make this a global variable, and then use parameters sweep analysis to sweep this.
    This global variable can also be an expression. You need to use curly braces for defining variable or expression ex: {pulsewidth}
    Hope this helps.=
  • karan75
    karan75 over 14 years ago
    Amira Foods – One of the largest privately owned Rice Company from India. Amira is one of the largest manufacturers.
    http://amirafoods.co.uk/karanchanana.html
  • amrity
    amrity over 9 years ago
    Hi Alokt,
    Could you please tell me how to vary pulse width of vpulse source in details ? Actually I need to adjust cycle in PWM block for dc-dc converter. At this moment I am using fixed duty cycle for vpulse. But don't know how to var duty cycle.
